Upgrade A/V or add power amp ?
Discussion in 'AV Receivers & Amplifiers' started by Mike-M, Apr 4, 2005.
  1. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    I have around a grand to either upgrade from my current Denon 2105 to the 3805 or add power amps to the 2105 and don't know which way to go.
    I have a Rotel RB-03 which I have tried with the 2105 on the fronts and found that to be a step in the right direction. In light of this I am wondering if I should add a three cannel amp for the fronts and use the rotel for the rears, look to get a five channel amp or as I said at the start, change to the 3805.
    All opinions would be most welcome.
  2. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Hmmmm, lots of possibilities. And the 2105 would be a relatively recent purchase.
    Are you trying to improve the stereo ability of your system? What problem had you identified in your system that required the 'experiment' of the power amp? What is the rest of your system?
    Sorry for the questions, but everyones situation is different. And the power amp upgrade is no a one size fits all.
  3. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    Hi Harry T2,
    Thank's for the reply. I have two setups at the moment for movies and music. I really want to combine them into one. The music comes through a Quad / Dac20 combo at the moment and I suppose I am trying to match this quality (as close as I can) with the movie setup. I will of course continue to use the Dac for the music.
    So this is my main thrust.
    Of course, if I end up with some improvement with movie sound I won't be disapointed.
  4. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    I would get a GBP1000 integrated amp.
    I think the pre-amp section of the 2105 will always be the weak link and will never give the returns you are looking for.
    I would strongly recommend that you listen to other integrated in the price range as their a lot of very good amps (and very few bad ones).
  5. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    Can you give me more info on the GBP1000, I've done a search but come up blank
  6. deanym
    deanym
    May 29, 2004
    1,802
    +142
    gbp means gb pounds! :smashin:
    £1000 :D
  7. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    LOL, I meant Great British Pound. I was lazy and couldn't be bothered going into word and copying the £ symbol.
    Not everyone is located in the "mother country". Some of us are in the "colonies".
    (Edit), Thanks, deanym. Beat me to it.
  8. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    :oops: Don't I fell like a prat now.
  9. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    Or even "FEEL". I think I need a lay down in a darkened room for a while !
  10. deanym
    deanym
    May 29, 2004
    1,802
    +142
    Just being converting euros/dollars and pounds at work!! - still fresh in ma heed.
    No sarcasm was intended!!
    By the way, ebay has some Musical fidelity integrated amps for auction. You'd do a hell of a lot worse for two channel.
  11. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Does that mean you no longer use pounds? :rolleyes:
    About time you start using a PROPER currency :thumbsup: :devil:
    Does it mean I have to find the bl**dy Euro symbol now? :thumbsdow
    Anyway, is the budget 1000 Great British Pounds or 1000 Euro?
  12. deanym
    deanym
    May 29, 2004
    1,802
    +142
    its an american firm so its dollars - easier to find on the keyboard!
  13. Mike-M
    Mike-M
    Oct 13, 2004
    1,308
    48
    Lincoln
    +32
    It's £1,000 of our English pounds.
    At the risk of sounding like a Pr**t again. Harry, Why can't you use shift 3 for the £ sign?
  14. Harry T2
    Harry T2
    Jul 29, 2004
    482
    +10
    Think we are getting way of topic :D
    But the Shift 3 is the # on my keyboard. The shortcut in Word is something like Alt 0163. I think I would need to go into Windows and change by setting from English - Australian to something else.
  15. Daneel
    Daneel
    Dec 5, 2002
    2,833
    68
    London
    +8
    I'd go with the power amp option. 2nd hand if you are not adverse to such things.
