gadgetfreaky1
My home theater is about 19' x 14x with 10' ceilings. I have in wall B&W CWM 8.3D for FLR In-Wall Speakers - Hidden Speakers | Bowers & Wilkins
I have 4 of the CT SW12 subwoofers In-Wall Speakers - Hidden Speakers | Bowers & Wilkins with 2 in front, 2 in the back (hanging above seating area facing down) with 2 SA 1000 amps powering the 4 speakers (2 speakers per amp)
But the subs just don't get low enough, I don't "feel" the bass, it's plenty loud, plenty punchy but I really want the subsonic feel. Because of WAF factor, I can't have any subs sitting on the floor outside the in wall cabinet I built. there is a cabinet up front that I would install the subs into. But I'm limited by about 19" depth, 19" width, and 28" height.
I really wanted the B&W DB1D which i've heard at a friends house, it's bone crushing amazing. one would easily fill the room but given it's 2 woofers, I cant have it in the cabinet , it would have to sit outside on the right of the screen, which still isn't ideal since it'd be sandwiched between the wall and the cabinet.
I've been looking at the SVS SB4000 , unfortunately the SB ultra won't fit, and the JLL F112v2 (as the 113 won't fit) just a bit too deep. Given I need another inch for cabling behind i mnight be able to cut into the drywall and get cables in there.
BTW, current cable from the sub spot is speaker wires since the amp is in the rack, can I just use a speaker cable to RCA cable and use the same speaker wire with new sub or do I have to run a rca line?
Also I had contacted deepseasubwoofers, DAvid said he could build a custom marina 18s subwoofer with 4,000 watts to fit inside the cabinet.
Would love everyone's thoughts? Do I yank all 4 subs, put in 1 deepsea? 2? 1 or 2 SVS? 1 JLL?
