Afternoon all
Nice Pick ELV, are you going to post a thread on it? (I haven't seen one if you've done so already but then I've been busy with Work and the below, I'd be interested in your setup).
The Sony is bedding in nicely and after a weekend of room moving about and furniture building I thought it was about time for some pics.
First the beast straight out of the packaging before the tempting-tempting removal of the protective film...mmmm...peely.
Little bit of a size difference to my trusty AE300, I do believe the Panny was worried it may get eaten at this point
View attachment 830947 View attachment 830948
So as I mentioned in my original post, the Panny had been used on a tripod mount, well that wasnt going to work for the Sony. I looked at ceiling mounting it but the joists run the wrong way in this room and while we rent from family so have lots of leeway, the kind of structural gubbins I'd need to do to hang this beast was discounted. So firstly worked out the height that was going to be needed - was spot on the calculations I got out of Projector Central. Here's the Sony on a makeshift stand (occasional table on the main table - Mmmmm blends in with the room - what projector? - lol). The "new" well new to my system back 7.1 surrounds are there as well on my home made speaker shelves.
So after a mid week Marvel movie it was a holding pattern until the weekend and a trip to Argos (well two due to stock being in different branches) for a couple of appropriate height storage units. These have been put together and bolted to the wall. Although they are pretty sturdy anyway didnt want to take any chances with a 12 year old and two kittens in the house as well as taking chances on my projector nose diving.
I also took the opportunity to sort out the speaker cabling into new conduit. Was pretty late on Sunday by the time I finished so apologies for the darker picture.
The LED / glass beads are turned off for movies obviously.
View attachment 830951 View attachment 830952
So up with the current screen (its a homemade 300cm wide by 135cm high creation that attaches to wall hooks and is tensioned by turnbuckles - we just roll it up when not in use) and movie time.
Two movies Jurassic Park and then Titan AE. Just quick screen grabs while we watched from my Samsung phone here, actual picture looks a lot better. Jurassic Park is obviously 1.85:1 so uses no zoom at all just the lens shift to nudge it over a bit as the radiator stops me putting the projector unit dead center. Titan AE is 2.35:1 so I thought I'd try zooming it up to fill the height. The Sony had no issues with it even on low bulb and the space animations look very nice with dark blacks.
Im feeding the sony via an active QED HDMI lead from a Yamaha RX-V673 from a SKY HD, media PC running Kodi, (I dont have everything ripped to my back end 10TB Unraid server as it would soon fill) I do also have the option to play from my old but trusty PS3 anyway and it's still a pretty decent BluRay player even if it's not in the league of some of the new Oppos etc.
View attachment 830953 View attachment 830954
So next step is to build a new screen. This will be a rigid framed screen at 300cm wide by 145cm high to allow me a number of framing options, it will be a wood frame and will have patterned fabic on the back doubling as wall art when not used. It will hang on the wall to the left of the TV wall and simply be lifted from one wall to another.
Due to the loft (again) an electric screen wouldn't work in the room without some serious changes and a large enough sized screen would be prohibitively expensive anyway. So for now some more DIY will be coming. In the meantime I will tweak the existing screen as there's a tension ripple in the bottom right side which does show if there's a block of light colour so I'll correct that until we can move the room around (including a bookcase which is full, reaaaally full, of books) to allow a large piece of "wall art" to hang there
Cheers all
Ed
Welcome to the club Sir ! Your pics remind me just how nice an image the Sony throws out with very little adjustment beyond Reference mode, low lamp and maybe Gamma 2.4.
