Updating AVR300 firmware: Modem Cable question
Discussion in 'Arcam Owners' Forum' started by addiwei, Sep 7, 2005.
  1. addiwei
    addiwei
    Sep 7, 2005
    59
    I have an IBM T41 laptop. My laptop does not have a serial port (that I know of) It does, however, have a LPT1 parallel port for Printer though. Can I use a 25pin Serial cord and connect it to the receiver to do the update?
    Also, if I can do the update this way(using the printer port), which Com port do I specify in the AVR300 software ? (Com1, 2, 3, or 4) ?
    If I can't physically perform the scenario above..I would need to buy a USB-serial port adapter, and select which COM port?....Thanks in advance.
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    You need an RS232 serial port, not anthing else. You can try using a USB to serial adapter but they do not always work as they only emulate a serial port and are nota true one. If you are at all unsure about soing this update yourself then get your dealer to do it as you may end up with a dead machine and a hefty repair bill. You have been warned.
  3. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    I wondered how long it would be before IT companies dropped the old serial port, but I didn't realise we were there already. I think you will have to borrow a PC or take it to a dealer.
    I note the Meridian G series have USB as well as serial sockets, but I don't think they actually do anything yet (the manual says for future applications)
  4. LFCRules
    LFCRules
    Sep 3, 2004
    2,670
    +188
    Hi addiwei,
    I have a IBM R30 laptop at home, and it also has no serial port. I got myself a USB to serial port lead, and plugged in the NULL serial cable into it and it works a treat. I've done 3 upgrades myself so far. I have had problems with the initial connection being established prior to upload of new software, as Crusty says this could be caused by the USB to serial lead, but after a PC reboot and following the instructions EXACTLY, it has worked.
    As Crusty has said though, be warned you are doing it at your own risk, it goes wrong you pay for it, whereas if the dealer does it, they pay for it if it they mess it up ;)
    Cheers,
    Andy
  5. addiwei
    addiwei
    Sep 7, 2005
    59
    now I'm all scared to do it myself. I bought my unit from an online user, so I doubt the local dealer's going to touch it. Any suggestions?
  6. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    Finally found a use for my 5yr old Thinkpad T23--they still had serial ports :)
  7. Hifi addict
    Hifi addict
    I used to have a T41 myself as well and I seem to remember that it has a 9-pin serial interface, not the old 25 pin one.
  8. addiwei
    addiwei
    Sep 7, 2005
    59
    isn't that 9-pn serial interface for the output to a monitor though? it's a monitor out... other than that 1..there aren't any others.
  9. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    That is a display port, not a serial port (the gender is different). On the newer Thinkpads, they got rid of the serial card. You need a PCMCIA to serial interface.
  10. Hifi addict
    Hifi addict
    monitor is not a 9-pin connection. I thought I used a serial port to connect my mouse to. Could be that it's a round connector. If your pc has one then you better use that one
  11. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,521
    Edinburgh
    +1,239
    It depends on how good a rapport you have with your local dealer. If you have bought other stuff from him and have generally been a reliable source of custom then I'm sure he'd be happy to help out if he can.
