Update your new Jasper
Discussion in 'Xbox Forums' started by pure_geordie, Feb 9, 2009.
  1. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    Hello Chaps. Basic question with a basic answer. Before I download and install the latest software patch 2.0.7363.0 from microsoft is it safe to do so?
    Ta.
  2. Mr_Belowski
    Mr_Belowski
    Mar 20, 2003
    777
    63
    Loughborough
    +281
    My Jasper Acarde box updated itself last night, and seems to work fine
  3. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    well, unless you plan on playing offline for ever, theres no getting round it.
    these updates are forced on you, and theres no getting round it.
    if anything intoward happens, your covered either by the retailer,or by microsoft.
  4. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    It doesn't go online as I don't have any use for it. So is it worth it?
    Thanks.
  5. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +4,289
    in that case, not really, no.
    its all bells and whistles really,nothing of any use if offline is what you plan on doing.
    but, if you have a problem with a game, and it needs a patch/update, then live is the only place to get it, but you would have to update the console first..so take that into effect.
    the update will eat a good portion of your onboard memory(i assume you dont have an xbox with a memory card, as its a jasper), so be prepared to either buy a memory card or hard drive in the near future.
  6. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    Real guitars don't have strings, they have 5 colou
    +934
    Without an HDD you have to download game patches everytime you play the game, or that is what I have been told, that would be annoying.
    I personally recommend keeping devices updated, and all future retail games(gold after NXE launch) will ship with the NXE and force you to update anyway.
  7. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    OK Thanks you for your advices.
    I'll go ahead and download and install anyway.:rolleyes: I just thought that since it is working OK I don't want to brick it. I've heard that the latest patch breaks it.
    see here: Mandatory update that fixes HDMI audio issues caused by the New Xbox Experience update.[5]
    NOTE: Update has been reported to brick to your console.
    Xbox 360 System Software - Wikipedia, the free encyclopedia
    Thanks.
  8. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    +934
    Every update bricks your console, there is not a single 360 patch that hasn't 'bricked' a console.
  9. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    Bricked a console. Doesn't that mean Break, rendering it in-operable. I'd rather not do the update then.
  10. WillieCocker
    WillieCocker
    Sep 5, 2008
    1,533
    Dublin, Ireland.
    +111
    The term "bricked" is used to describe a console that is rendered useless/in need of repair after an update.
  11. delucep
    delucep
    Dec 10, 2005
    3,305
    +984
    Bricked does indeed mean break..
    As Matt said, every time M$ release a patch a small percentage of consoles brick on or very quickly afterwards.. Normally (but not always) these are older consoles.
  12. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    So bottom line is.
    Update AYOR
    Reading a few of the threads here I think I'll just leave it as is.
    If its not broke don't fix it.:D
  13. WillieCocker
    WillieCocker
    Sep 5, 2008
    1,533
    Dublin, Ireland.
    +111
    No bottom line is, you must update to use the 360 as it was designed, and you should only really worry if you have a launch console or one older than 2 years or so.
  14. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    OK I see. Just bought my new japser model only the other day.
    I'll not worry about it.
    Ta
  15. WillieCocker
    WillieCocker
    Sep 5, 2008
    1,533
    Dublin, Ireland.
    +111
    I certainly wouldn't.
    My year old Elite is going strong with no problems at all.
  16. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    Just out of interest what does the latest patch consist of.
    Is it going to make it quieter and run faster:D
    It will also half my memory of 256MB as well:(
  17. AdsterUK
    AdsterUK
    Nov 4, 2003
    1,005
    Sunderland
    +81
    It fixes audio problems using a HDMI lead.
    Personally I have no problem doing any updates, you generally hear second hand reports of tens or possibly hundreds of people who have a problem with an update, thats out of the millions who own a 360 console.
  18. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    I Don't have audio problems using an HDMI lead. I have had problems doing updates with the xbox before.
    I'm obviously being over cautious because I did have an eggbox 360 about 2 years ago and it broke after an update and now I have a new one so i'm a bit worried.
    But what the hell what could possibly go wrong.
  19. Chrisoldinho
    Chrisoldinho
    Feb 7, 2006
    3,445
    Leeds
    +267
    I'm running a release day Xbox Core and I have downloaded every update to date.
    Had it RROD on me once but this was nothing to do with an update.
    Every console runs a small risk of getting "bricked" when updating, but:
    A) MS aren't going to knowingly release a patch that will brick your Xbox and it will of been tested to the Nth degree so i'm sure you'll be fine.
    B) The consoles that usually get bricked are the result of someone doing something stupid like turning the power off during an update / electricity going off.
    C) Jasper units are much much better than the older chipsets so again, chances reduced
    D) Updates are there for a reason, they fix something wrong. Be it a simple HDMI audio fix through to a whole new Dashboard.
    E) Even if you do only go offline surely it's good to know your running the latest software that has hotfixes against any issue previously.
    Updating is an inevitable part of today's computing market and something can always go wrong. But even if the worst did ever happen (99.99999% won't) then you can always get it repaired FOC by MS for 3 years or your local retailer for 1 year usually and if a 3 year old Core 360 can update no probs after so much abuse over the years (500 hours+ in COD4 alone, 300 hours on WaW and atleast this on COD3, PGR3, Orange Box to name but a few combined) then i'm sure a brand spanking new Jasper can take it!
    Chris.
  20. pure_geordie
    pure_geordie
    Mar 13, 2006
    1,112
    +60
    OK, but am I right in saying I will lose 128MB after the update. leaving me with 128MB, As I don't have a HDD.
    Could I also uninstall some features of the update to give me back more HD space?
  21. mattclarkie
    mattclarkie
    Sep 13, 2007
    11,987
    +934
    Every update that has ever been released has bricked something. Somebody will always have a bad update, from MP3 players, to TVs, to games consoles, changing the firmware is risky.
  22. xox Godders xox
    xox Godders xox
    Jan 2, 2008
    1,421
    +316
    No, afraid not.
