Update XP and W2K now !!
Discussion in 'Desktop & Laptop Computers Forum' started by HMHB, Aug 12, 2003.
  1. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    Anyone who is on Windows XP or Windows 2000 should do an update now if they haven't already done so. There is a virus (worm type) creating a bit of havoc at the moment which Microsoft issued a patch for back in July - but a lot of people aren't running the auto update and so have been infected.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    I got caught last night. I phoned our Computer support dept. but the worm was too new for them to have any decent advice.
    I am in the clear now.
    You need the latest virus defs (dated yesterday or today) and even then they are not guaranteed to spot it !
    Clues : You get an error message to the effect that svchost.exe is closing down .
    (result of this is that some windows functions are disabled e.g. “Start-search” will not work.).
    It’s quite inconvenient running a PC with Service Control Manager disabled.
    Check "Processes" in Task-Manager ; if you see "msblast.exe" you have the worm.
    It normally installs it in \Winnt\system32\ folder (make sure you can "view all files " including system files).
    It cleverly uses TFTP (Trivial FTP) to download and install the program/worm from a remote site. It listens on UDP port 69 but may also use other ports.
    Once you or your virus-checker has cleared it, reboot before downloading Microsoft security patch KB 823980.
    I suggest a further reboot and closing all other programs before running the patch.
    A final reboot is then needed before your system is clear.
    Chris Muriel, Manchester.
  3. HMHB
    HMHB
    Nov 11, 2001
    25,516
    Nottinghamshire
    +3,852
    I posted this in the general forum as well as here. So if anyone wants further information:-
    Virus Warning
  4. zAndy1
    zAndy1
    Nov 26, 2002
    19,614
    2
    5
    163
    +6,714
    Glad I had a firewall tonight! Got a 'TFTP is trying to access the internet' message asking if I wanted to grant access. Of course I blocked it. Then my PC shutdown automatically for some reason, anyway I've done a scan and it seems I'm virus free but think that was a close call!
    Cheers,
    Andy.
  5. Pulsar
    Pulsar
    Jan 19, 2003
    2,922
    West Midlands - Stourbridge
    +292
    I got caught out by this, decided to blank all of my hard drives in an attempt to fix the problem. Oh well, I now 180 gig to fill back up.
    Rob
  6. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,130
    Damn I think I've got this. Machine seemed a little suspect recentlt ..lock ups . explorer not working on initial boot up and the svhosts.exe closing due to errors. I thought it was because I had been mucking about with my wireless network.
    I downloaded and installed AVG the other day and it certified that my machine was free of viruses. This was literally yesterday!
    I'll apply the patch.... damned if I'm doing another clean install if I can help it.
  7. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,100
    Manchester
    +712
    SvcHost.exe closing with errors is a common symptom of this.
    It will stop many right-click functions working amongst other things.
    Delete any instance of msblast.exe.
    Ensure your virus-checker has latest updates.
    Install that service patch.
    The worm does NOT damage your datafiles , fortunately.
    It's a very clever/insidious mechanism that it uses.
    Chris Muriel.
  8. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,130
    Yep I've found it alright.
  9. MarkHudds
    MarkHudds
    Jun 12, 2002
    548
    +4
  10. Mr.D
    Mr.D
    Jul 14, 2000
    11,051
    +1,130
    Latest version of AVG handles it . Just don't know why it didn't find it yesterday: its not as if its updated itself in the meantime.
