update sky software.
Discussion in 'Sky Digital TV Forum' started by gooner1, Aug 9, 2004.
  1. gooner1
    gooner1
    How do you update the Sky software on the Sky plus box. Or is it done automatically.
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,144
    41
    NW London
    +17
    it should be done automatically, but if you havnt had it done or you want it done NOW. then pull the power plug out of the sky box, then, while holding the backup button on the sky box, plug the power back in, wait 5 seconds or something, you should get an update screen, wait till that finishes, then wait another min and the box will turn on with new firmware. Hope this helps
