Update loop
Ionfly
hi all,
had a few bits n pieces laying around from broken ps3s and wanted to see if i couldn't get 1 or 2 of them working. to test if i had the correct logic board installed and not a faulty br laser, i downloaded some demos from psn to see if they would play or i get blackscreen. to download from psn i updated to 4.11, but during this update a couple of the machines got caught in a loop and the update failed. the problem is with the incorrect logic board, or some other br problem. is there an y way to fix this? i have tried changing br drives, so get different logic boards, so hopefully get a successful update, to no avail. i have attempted to update from pup files via flash drive, but nothing does for this method. any help is will be very much appreciate.
so many thanks to you.
ionfly
Podcast: Sony XH95 TV, Klipsch The Fives Speakers & Bias Light Reviews + Best of the Month
