upconverting amps
Discussion in 'AV Receivers & Amplifiers' started by jimbowley, Oct 28, 2004.
  1. jimbowley
    jimbowley
    Oct 24, 2004
    158
    16
    could someone explain very briefly how they normally operate. And give me an example of a decent budget one £300?
    Do they for instance upconvert everything to YUV and then have a single ouput.
    thanks
  2. andhoey
    andhoey
    Jul 23, 2004
    80
    9
    check out the yamaha dspax750se i think this is the only one in your price range that converts to yuv. the sony strdb795 also has some upconversion.
