upconvert to 1080i
Discussion in 'General TV Discussions Forum' started by jules19, Jul 8, 2005.
  1. jules19
    jules19
    just a v brief question:
    i saw all the press releases for the new S lifestyle series from denon- the s-101 and the s-301.
    apparently the latter of the two can upconvert to high definition resolutions over HDMI, 720p and 1080i
    so would you think that this bit of kit could be classed as HD ready ???
    previously I had read that it could only upconvert video over component , but this latest round of press releases say it can do it over HDMI.
    any input appreciated- you guys have got from now until august to get back to me (the releases dates for said machines)
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The HD Ready label only applies to displays (or so I believe).
    A bit hazy on this but I thought it was the other way around and the majority of DVD players with the capabilty of scaling an image would only allow this via a DVI or HDMI connection.
    Nice looking bit of kit though:)
  3. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    I have a Denond 3910 which can also upconvert to 720p or 1080i over HDMI or DVI-D.
    Picture is better than regular DVD if you are watching on a good HD panel. (LCD or Plasma).
    Still, this IS NOT true HD as the source material (ie the DVDs) arent HD.
    True HD will be an HD format like Blu Ray or HD DVD on an HD panel that can handle HD resolutions.
    Just because its an LCD or a plasma doesnt mean its true HD.
    The resolution should support a minimum of 1280X720 (720p) or the optimum HD resolution of 1920X1080 (1080i/p)
    The only other thing you would need is an HDMI or DVI-D conection.
  4. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    to Add to AML. your DVI-D socket needs to be HDCP complient and both 720p and 1080i signals must be accpeted at 50 and 60hz for a display to be classed a HD panel
  5. jules19
    jules19
    thanks for the reply guys,
    just to let you know, I have a supposedly hd ready tv- supports formats at both 50hz and 60hz and has hdmi port on the back of the set.
    so based on what has been written, will the new denon lifestyle series be able to handle the new HD dvd's??? or am i best waiting for a newer version to arrive?
  6. scumball
    scumball
    Jan 12, 2004
    6,472
    Harrow - London
    +440
    No there are no commercial HD-DVD/Blu-Ray players available in Europe.
  7. jules19
    jules19
    with this not being released until august perhaps this system may be able to play hd dvd???
    is it worth spending 900quid or should one wait until true hd dvd systems are on the market?
  8. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    HD-DVD is a totally different beast to the current DVD spec, no domestic DVD player on the UK market now will handle the blue laser discs.
    You will be waiting a long time for an affordable system to be on the UK market and certainly at a much higer price point then your £900 for this model. I suspect you would get good performace and enjoyment from this system and you can then add a HD-DVD player at a later date assuming you have a suitable HD Ready display since HDMI is a requirment (at least on paper).
