Anjou
Established Member
I was planning to buy the 30PF9975 but I just read the specs on the upcoming 32PF9986, which sound very interesting. However, I'm a bit confused on one point - the screen says it does progressive and even lists 720p but doesn't have phono component inputs or a normal VGA connector. However, it does have a DVI socket.
While I can see that you may be able to buy a VGA to DVI convertor for older PCs, how could you connect something with a normal YUV progressive component input to this screen?
Or is this another classic Philips getting it only 99% right.
