UPC numbers for R2 next gen?
Discussion in 'Movie Forum' started by Gibbster, Jan 3, 2004.
  1. Gibbster
    Gibbster
    Can anyone help out with the UPC numbers for Season six and seven of the Next Generation?
    I through away the outer wraps and can't find them by title in the DVD Profiler database.
    Thanks in advance for your help!
  2. Fatti
    Fatti
    Oct 22, 2002
    658
    Worcester
    +40
    Gibbster, give these a try:
    For Season 6: 5014437821836
    For Season 7: 5014437821935
    Hope this helps.
  3. Gibbster
    Gibbster
    Thanks - but unfortunately they don't work :(
    Any other suggestions?
  4. Fatti
    Fatti
    Oct 22, 2002
    658
    Worcester
    +40
    Very strange.:confused:
    If I put 5014437821836 (Season 6) into DVD Profiler (Add DVD By UPC) I get "Star Trek: The Next Generation - Series 6: Box Set"
    If I put 5014437821935 (Season 7) into DVD Profiler I get the choice of "Star Trek: The Next Generation - Series 7: Box Set (United Kingdom)" or "Star Trek: The Next Generation - Seizoen 7: Box Set (Netherlands)"
    Sorry if this is obvious, but when you add a DVD by UPC does it connect to the online database and update all the proflies, images, online pricing etc.
  5. graham.myers
    graham.myers
    Mar 11, 2003
    6,220
    Leeds
    +932
    if you click on the "my obsession" link below I have series one to seven. if you select the title the first item on right will be the upc code
  6. Gibbster
    Gibbster
    Thanks Graham - that did the trick!
    Fatti, thanks for your efforts but not too sure about those numbers - they are totally different to the correct ones, and I have the latest database downloaded.
    But I do appreciate your efforts - thanks guys!
  7. Fatti
    Fatti
    Oct 22, 2002
    658
    Worcester
    +40
    I've just realised that the numbers I got from www.mvc.co.uk include the 5 as the prefix (think is something to do with the country code, 5 being the UK ??)
    Although they seem to work for me, try them without the 5, i.e.
    For Season 6: 014437821836
    For Season 7: 014437821935
    Sorry for the confusion.
  8. Gibbster
    Gibbster
    ahhhh,
    that probably explains it!
    Don't apologise - I appreciate your efforts to help.
