Up to 32 inch tv for PS5
x7nofate
Hello everyone, hopefully this is a good place for this topic.
I finally got my PS5 and now need tv, however I can not find tv under 32inch which would use full potential of the next gen consol.
Please could you recommend tv between 28-32 inch for PS5 with all the required spec:
HDMI 2.1
HFR
ALLM
VRR
eARC
HDR in Dolby Vision or HDR10+
4K
Price does not matter
Please dear experts send me some recommendations.
x7nofate
Thank you for your answer unfortunately this Samsung is hdmi 2.0 only. What is the smaller tv/monitor with all the spec requrie for PS5?
Toasty
You don't need a 2.1 hdmi TV for PS5 if that's your concern, you can hook it up to any display with a hdmi slot.
x7nofate
Yes I know I can hook up to any display but hdmi 2.0 does not support
HFR
ALLM
VRR
eARC
Which is crucial to use full potential of PS5
Toasty
I'm not sure any of that is crucial and PS5 doesn't currently support VRR, but good luck sourcing what you're after.
x7nofate
Hdmi 2.1 for for TV, this is monitor with 2.0 but it does support:
120 hz overclock to 144hz = HRF
4ms input lag = VRR + ALLM
HDR 1000 = dolby vision or HDR10+
Toasty
Indeed, but you wouldn't get 4k @ 120hz, although I doubt many games do that lol, but would get 1080p @ 120hz with this display. Don't think it has eArc either, but didn't look too far.
x7nofate
Not today but in the future will be games running at 120fps. I buy display once for many years, don't want to spend monay twice for display. I want to buy once and good so will be ready for any game and want to use full potential of next gen consol. What is the point to buy ps5 and use bad display? Better stay with ps4 then
Toasty
There are games now that run at 120fps, but with the display you posted, you'd only get 1080p, you need HDMI 2.1 to get 4k @ 120fps..
sykotik
I was in the same boat a month ago , looking for a small tv for the man cave
the only "small" tv i could find at the time with all the boxes ticked was the LG nano 86 at 49inch
HDR
Freesync
4k 120hz
low latency mode
couldn't find anything else smaller
having said 49in i was lucky enough to get the 55in version for about £540 on amazon prime day
the picture is nothing like the LG OLED's (blacks could be blacker) !! but for a "gaming" tv it's decent and im happy with it :)
sykotik
Most of higher end LG tv's have all the options but are quite expensive and only are in 49+inch version.
Mallett94
HDR
Freesync
4k 120hz
low latency mode
I'd try expermenting with turning HDR off on the PS5 with that TV. It's HDR performance isn't great. However you should be able to get a good 4K 120fps SDR performance from it.
Pillow Lover
I've got a 49" TV and the difference between 4K & 1080 isn't exactly earth shattering. I wouldn't concern myself with it on 32" TV.
sykotik
I'll give that try and see if a get a better picture , thanks
but to be honest im happy with the TV.
at the end of day i wanted "something" for the man cave didn't have to be top of line with the blackest of blacks but have a few bell and whistles..... just something to use with the Ps5 and PC ..and sit back and chill :)
Mallett94
Yeah it's not bad. It's IPS which isn't as good as VA but it does have HDMI 2.1 and supports [email protected] so you do have that. I would certainly try using it with HDR turned off on your HDMI connected devices though because it doesn't have a good enough spec to do HDR well. You should be able to get an extremely good SDR image though. Make sure you set the TV to game picture mode and maybe even also try labeling the HDMI input to a games console or PC to ensure minimal input lag etc.
sykotik
@Mallett94 by all means i'll give a try , HDR games do look good and as say it's not the best when it comes to HDR -- but if there's a better picture i'll try it , thanks
ozzzy189
I've been playing doom eternal at 120fps and there's no way I'm playing at 60fps after, it's miles smoother and more responsive.
Cold War was the same. It's unfortunate that there's a bit of a visual hit but in games like those two it really doesn't matter.
Can't you squeeze an LG 48CX in or wait for them to bring out their 32?
Podcast: The Best TVs of 2021, plus our favourite & memorable reviews of the year
Latest News
Sky to share F1 decider with Channel 4 in UK
  • By Andy Bassett
  • Published
AVForums Podcast: 8th December 2021
  • By Phil Hinton
  • Published
Cabasse adds Apple AirPlay to Pearl Collection speakers
  • By Andy Bassett
  • Published
Vestel launches TV remote app for 50 TV brands
  • By Andy Bassett
  • Published
Velodyne shipping new MicroVee X compact subwoofer in UK
  • By Andy Bassett
  • Published
