Up to £550 for gaming LED - suggestions?
howieeb
Hey all - can anyone suggest and LED for 100% gaming. It doesn't have to be anything fancy, just something that handles motion well enough and doesn't suffer from high input lag. Around 40" if possible.
vickster
howieeb
Cheers for the suggestion, Vickster. I actually have a 42ST30 that i'm returning. It's brilliant for movies and general tv, and games feel nice and responsive, but I see phosphor trails everywhere. If it was for a general use tv I would be more than happy, especially for the price, but as I see phosphor trailing more than most people (I see green flashes every other second while playing fps) and as the tv is only used for gaming, I have to go to the grey side :/
vickster
Oh dear :(
Not sure what is low lag on the LED front - Panasonics good - 42E30 perhaps but over budget Sevenoaks Sound and Vision - Panasonic TX-L42E30 <p>42" LED TV (Full HD) <p>(Save £270) (Claim Free 5 Year Warranty)
Or the 42E3 Panasonic TX-L42E3B(TXL42E3B) 42 inch VIERA,Full HD 1080p,LED Edgelit IPS Alpha LCD TV, Freeview HD at best prices.Buy cheap at a low price At Sound and Vision Bolton.Free Review/Test.Free Delivery
Not sure on the Sonys - there are a few reviews of current models on here - I don't think they are worse on the lag than the Samsungs for example
e.g. http://www.avforums.com/review/Sony-EX524-(KDL-40EX524)-40-Inch-LED-LCD-TV-Review.html
Where are you returning it to? Do you have to buy from the same retailer?
Pistachio
I have been looking for a similar tv. I wanted a thin LED to mount on the wall without protruding mainly for gaming use.
In addition to the ones above, it may be worth considering the 5 series samsungs which are in your price range. According to TachRadar in game mode the input lag was 35ms. I am still undecided though. These tvs are not 100hz, but have Clear Rate Motion 100, which is meant to be an improvement over 50Hz?
howieeb
Thanks again, Vickster. I'll look into that. I got the set from Amazon who are usually good with returns. It really pains me to send the ST30 back as blu-rays look absolutely stunning - if I had the cash i'd keep it for the lounge and get an additonal gaming tv!
Cheers, Pistachio - I just had a look at the Samsungs. The UE40D5520 looks decent. I'm also considering the Sony 40EX723. Motion wise I was under the impression that any processing is best turned off while gaming anyways and that 50hz for lcd/led is prefered?
Similar threads
LG CX 4K OLED TV Review: The best TV of 2020?
