up-scaling and up-converting
Discussion in 'LCD & LED LCD TVs Forum' started by beardo1976, Sep 14, 2007.
Tags:
  1. beardo1976
    beardo1976
    Hey guys,
    Can anyone give me a laymans definition of the differences between up-scaling and up-converting? Any help would be much appreciated!
    Jason
  2. nwgarratt
    nwgarratt
    May 5, 2002
    27,775
    +3,190
    They mean the same thing but up scaling is the more common term. It is taking a resolution and interpolating it to create a bigger resolution (like with resizing a photo) which is usually 720p or 1080i/1080p. A TV will also upscale itself to match the resolution of the panel inside.
  3. kingjude
    kingjude
    Sep 14, 2007
    62
    can u upscale using a graphics card.. like nvidia 8600gt?? it has a dual dvi link...so i would get a dual dvi cable to hdmi so i can connect my pc to the lcd tv... and its like an upscale?? my graphics card displays resolution of 2500 x 1600
  4. Collusion
    Collusion
    Sep 14, 2006
    254
    28
    Kuopio
    +42
    It is possible to upscale video with computer. But the scaling is usually done by the software, unless you get a driver, which allows your graphics card to do the scaling and de-interlacing. You should get the NVIDIA Purevideo Decoder, which is a high-quality decoder with video and audio features. However, the decoder applies only for MPEG2 video (DVD) and high-def material. So DIVX and XVID movies are still scaled by the software.
    For connecting your PC to your TV, you need to buy just a regular DVI-HDMI cable.
  5. Jules
    Jules
    Oct 11, 2000
    5,654
    137
    +1,162
    Actually upconverting and upscaling are completely different.
    Upscaling is as described above.
    Up-conversion is the process that changes the way the video is transferred from one device to another.
    e.g. you could connect your Sky box to an amplifier using an S-Video connector, and the amplifier might be able to 'up-convert' this signal to higher quality component video output.
    In this process the resolution of the picture does not change.
  6. nwgarratt
    nwgarratt
    May 5, 2002
    27,775
    +3,190
    If you google upconverting, plenty of manufacturers use ther term upconverting instead of upscaling.
    http://www.hkflix.com/xq/asp/infoID.35/qx/info.htm
  7. Jules
    Jules
    Oct 11, 2000
    5,654
    137
    +1,162
    Yes, it can be very confusing and even misleading.
    Their marketing guys sure make it difficult for people to get a handle on what they're paying for.
