Up Grading a Pioneer a DVL-909 DVD/LD
Discussion in 'Blu-ray & DVD Players & Recorders' started by Darth Vader, Feb 13, 2002.
  1. Darth Vader
    Darth Vader
    Feb 13, 2002
    102
    16
    Middlesex
    Can any one help?.
    I own a Pioneer DVL- 909 DVD/LD player and have heard you can upgrade the firmware in the machine to allow dts output through the digital outs.
    Is this a pipe dream or have my prayers been answered?.
    PS. I can't belive anyone has not picked Darth Vader before!
  2. General Skanky
    General Skanky
    Jul 28, 2000
    4,252
    71
    Colchester
    +44
    Have you looked at www.videotec.co.uk as they do things like that, normally by adding a DTS output specifically?
  3. Mattk
    Mattk
    Hi I have some info on moding the DVL-909 depending on what version you have. You can convert it by changing 2 surface mount resistors to a DVL-91 which outputs DTS- the only drawback is you effectively convert it to play NTSC only!! I have a copy of the webpage if you would like it emailed to you but it has since dissapeared off the net. The other thing is to unfortunately get hold of a 919, I have seen them down to £350 on auctions!
