Up from the Onkyo 505, Which is the next amp....
Tom Tom
OK,
So I have the Onkyo 505 and I like it (it was a 30th Birthday present from my sister) and don't really want to get rid of it. Especially as on ebay it now goes for £20 (if that)
My question is just going one run up the ladder (as I have no budget) which is the next amp that will actually process the sound from the HDMI, and has more HDMI inputs for the one HDMI out put.
(The 505 has 2 inputs 1 output and the amp does not process the feed just sends it through)
I now have
Freesat
Raspberry Pi
Xbox 360
PS3
all capable to HDMI sound but as it stands I have to put the 360 and PS3 into the amp through the 2 optical inputs.
The Free sat in on Phono leads and the Pi in on phono leads.
I don't want to have to spend a lot, I am not looking for the next best amp (even though I would like to)
I am just after an almost side step up in terms of quick set up, less wires at the back to make my system tidier and easier to manage if I need to move the whole unit about.
Tom
dante01
The Denon AVRX2000 is very good value for money at the moment and will cost you about £300.
Tom Tom
Yes 2nd hand, more than likely eBay. And where possible very cheap.
I would love to be able to really upgrade, but just at the mo want a small step to something like the onkyo 606 just to get the functionality I don't have, but not breaking my non existent budget.
PSM1
In that case I would steer clear of anything onkyo of that age as there is a common hdmi fault that can turn your AVR into a useless paperweight. Instead I would get something like the Sony 820 or even something from denon (19xx) or Yamaha (6xx) instead. As long as does audio over hdmi then you are good.
