techdiver
Established Member
- Joined
- Jun 25, 2014
- Messages
- 935
- Reaction score
- 482
- Points
- 199
- Age
- 42
I have a Sony A80J and a Denon AVR-X2200W. We recently got a PS5 so in order to benefit from 120Hz mode I need to plug the PS5 directly into the TV. This means audio t the receiver needs to go over ARC. I would loose any lossless audio and also have experienced server audio lag in some games.
I decided to purchase and eARC audio extractor from amazon here - Amazon product ASIN B08TX473Z8
Now I received it yesterday and everything was working perfectly. I attached the eARC port from my TV to the OUT1/eARC port on the extractor and then ran from OUT2 to an input (not ARC port) on my receiver.
This all worked fine until I plugged my cable from MONITOR1 port of the receiver back into the TV. Then the TV kept disconnecting from eARC and would only work if I toggled eARC mode off. Funnily enough sometimes it would work but after a power cycle it wouldn't. Once I plug out the MONITOR1 cable from the TV everything works fine again.
Now MONITOR1 is also the ARC port on the receiver. So I was thinking that because it is the ARC port on the receiver it is still trying to negotiate ARC with the TV even though it's not attached to the TV eARC/ARC port. So I went into the Denon setup and disabled ARC all together. This didn't fix the issue. The only way the Sony A80J will send eARC out through the device is if I don't have MONITOR1 attached to the TV. Using MONITOR2 is no issue.
This is clearly a bug, but I'm not sure which end is at fault. It appears to be some sort of feedback handshake loop.
The reason I use both outputs on the receiver is to have different picture presents based on devices being used. As a workaround I have temporarily attached my Nvidia Shield directly to the TV and can at least use the eARC extractor to pass the lossless audio back to the receiver, but this is not ideal for various cabling management issues.
Has anyone else encountered anything like this using an eARC extractor?
