Unsupported Soft Mod Games
Discussion in 'Xbox Forums' started by Matt TRD, Aug 8, 2005.
  1. Matt TRD
    Matt TRD
    Jun 28, 2005
    954
    Poole
    +68
    Ok i thought it might be a good idea to list games that do not run correctly once the High Def soft mod has been installed.
    I know it is easy enough to change the console back from NTSC to PAL but still think it would be usefull to know the problem titles.
    I will list the ones i have found so far please add to the list if you can.
    Unsupported:
    Fable
    Tiger Woods
