Unsheilded speakers and TVs - permanent damage?
Discussion in 'TVs' started by Lesmond, Mar 28, 2003.
  1. Lesmond
    Lesmond
    Jan 29, 2003
    +3
    Folks, if unsheilded speakers are placed near a TV for a while :nono: will this cause permanent damage to the TV? Will the discolouration be cured by the inbuilt degausing of the set? What other damage could it cause?
    Les
  2. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    i dont know about the tv but i put my speakers near the monitor of the computer and there was a patch of discoloration on the monitor , i just deguassed it and it was okay no problems.
    suspect the same with the tv .
  3. Johndm
    Johndm
    Jan 25, 2003
    1,813
    Bedford UK
    +56
    Degaussing will get rid of 'minor' discolouration, but I believe permanent damage will be done to the shadow mask in the TV if you leave them there for any length of time.....best move em away to be safe eh? :lesson:
  4. Pod Person
    Pod Person
    I ruined a 14 inch portable once by putting speakers too close to it. Even after degaussing it the colour purity was spoilt. The whites were very slightly yellow.
    I keep speakers well away from my current tv sets.
  5. mjm01
    mjm01
    Is this also an issue with rear projection sets or just 'tube' sets ??
  6. bommaren
    bommaren
    If the TV's built in degaussing is not
    enough, a TV repair shop can do a
    external degaussing.
    You can do it your self if you know how,
    You need physically large electro magnet, at least 40cm diagonally...
    won't tell you more, you can get your self electrocuted...
    -- B
  7. Achy
    Achy
    Oct 23, 2002
    296
    28
    +30
    How far away should speakers be ? Does it depend on their power?
    50cm ? 1m ? 2m ?
    Ta.
  8. Johndm
    Johndm
    Jan 25, 2003
    1,813
    Bedford UK
    +56
    I would suggest half a metre absolute minimum, preferably more.:lesson: (Unless someone else knows better):D
  9. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,819
    Somewhere in South Yorkshire
    +5,028
    It's the same issue, but with different end results and depends on the type of RPTV.
    If it happens to be a (fairly rare) LCD RPTV - there is no magnetic damage.
    If it is a (more likely) CRT RPTV, then magnetic interference will cause the convergence to go wrong (ie you may get coloured edges around things somewhere on the screen). It doesn't cause colour 'staining' as on a direct view CRT.
    And - for direct view LCD and Plasma - no effect from external magnetism.
  10. mjm01
    mjm01
    So, the fact that my front speakers are only approx an inch and a half from the side of my Toshiba 42pw23p (CRT RPTV) will likely only cause convergence issues that I can fix via user or service level convergence adjustment but with no permanent damage? ... Good !
    The closeness to the screen is dictated by room size and the old isosceles triangle approach for audio.
    When I just had a 32” widescreen set, I could have the speakers about half a meter away … and it didn’t seem to cause too much of a problem over 3 years.
    I can live with the requirement to do convergence adjustment every so often … something to fiddle with !!
    :smashin:
    Mark M
