Peter
with your specific TV, and need for a recorder only a home test/ Demo can tell you what you need to know as only then can your eyes
see the difference percieved or real.
Upscaling, whether via component with progressive scan or HDMI/DVI seems in different combinations of equipment to produce variable results. It is getting to the point where you dont really pay any extra for a budget to mid range DVD source which upscales.There are expensive scalers which are not the topic of this thread.
Your TVs internal scaler may or may not outshine the efforts of the scaler in the DVD player. There is really no way of telling without trying it out.
PQ quality in the sub £500 DVD players is rather more dependent on the image decoding ( mpeg decoding and deinterlacing) and less on upscaling ability
AND what do all these numbers 576 720 1020 whatever mean also this p/i
The nos refer to horizontal "scanning " lines which is how the motion pictures are made up in a display/Tv. and whether the motion picture is displayed as rapidly changing alternate lines ( interlaced) or a full picture of lines is built up ( progressive scan)
The more the no of lines the higher the resolution of the displayed picture. Those nos relate to what the DVD player can output as often the TV will not utilse all of them
The P is for progresive scan and I for interlaced.
In real HD sources the no of lines is more ( ie 720 ,1080) Upscaling aims to "make up" these extra lines from a source with only 576 to give the perception of HD. The idea is to utilise the available extra resolution of HD ready TVs from SD sources. Does it work?
