Unreal Torunament 2003 and GeForce Fx Problems?
Discussion in 'PC Gaming & Rigs' started by Nitro, Sep 20, 2003.
  1. Nitro
    Nitro
    Ok i just got my new video card 2 weeks ago GeForce FX 5600 256MB (EQ) i install Unreal torunament 2003, when i'm playing happend lots of weird things with the graphics i don't know why but the same happend with Unreal 2.
    Any help will be apreciate, Thanks.
  2. InsertNameHere
    InsertNameHere
    Sep 17, 2003
    264
    London
    +3
    Hi Nitro.
    Well, firstly make sure you have each of the games patched up to their latest version – that’s v2225 for UT2003 and v2001 for Unreal II. If the problem’s still occurring, try updating your video drivers. They can be obtained from either the manufacturer of your graphics card or from Nvidia themselves. The link to the latter is http://www.nvidia.com/content/drivers/drivers.asp. If you already have the latest version installed, I would give an older set of drivers a go. They can be obtained from either http://www.nvidia.com/object/win9x_archive.html (if you’re running Windows 95, 98 or ME) or from http://www.nvidia.com/object/winxp-2k_archive.html (if you’re running Windows 2000 or XP).
    Since you have an FX card just ensure you’re downloading detonator 4 drivers (4x.xx). ;)
    Hope that helps.
    Alex
    Oh, and make sure your system’s clean of any old drivers. You don't want them lingering. ;)
  3. Hawklord
    Hawklord
    Feb 15, 2003
    3,530
    3
    Aldershot, Hampshire
    +295
    You might want to download the latest version of direct x too.
  4. Kramer
    Kramer
    What kind of "weird things"? Weird geometric anomolies/distortion? "Specklies/sparklies"?
    Could also be a hardware problem. Overheating card, PSU not "man" enough etc...
    :smoke:
