Unofficial MacBook repair Manchester
Discussion in 'Apple Forum' started by maverick177uk, Jan 10, 2012.
  1. maverick177uk
    maverick177uk
    Jun 1, 2004
    5,456
    +1,116
    Ok my MacBook apparently according to Genius bar needs a new logic board, over £300 to do which I don't have. Has anyone used an unofficial repairer in the Manchester area that would hopefully be cheaper.
  2. marshallp
    marshallp
    Dec 29, 2003
    205
    Manchester
    +24
    Try Stockport Computers, their an Apple Specialist apparently. I've never used them myself but they have quite a few customer testimonials on their website.
    Good Luck!
  3. guest
    guest
    Sep 13, 2010
    752
    46
    +164
    The big cost with the logic board replacement is more the time in doing the work...(+ slice for apple) I have replaced several logic boards and it is a time consuming, screw intensive job. But having said that very easy.
    Have a look on ebay etc to find one and if you can lay out screws and use a small screw driver then do it your self....
    Good chance to upgrade the logic board to a newer model :)
    The new unibodys are a pain and expensive.
    I have used http://www.amsys.co.uk/ before and found them very good.
