Unlocking the volume on the VAIO pocket ?
Discussion in 'Headphones, Earphones & Portable Music' started by Xp_98, May 30, 2005.
  1. Xp_98
    Xp_98
    Hello
    Is there a way to unlock the volume on the Vaio pocket (VGF-AP1L), like it exists one for the NW-HD3 ?
  2. nealb
    nealb
    Nov 15, 2002
    193
    +5
    if you go into the set up menu you can turn off the volume limiter. mine was off by default.
  3. Xp_98
    Xp_98
    Thank you !
  4. SCO7T
    SCO7T
    Oct 20, 2004
    317
    +17
    hi there
    can you please explain how you turn the sound limiter off as in the setting menus all i can see is beep on/off and avsl on/off which is different to the sound limiter
    i have listed a full thread as well to this just incase
    hope you can help me
    many thanks
    scott lewis
  5. nealb
    nealb
    Nov 15, 2002
    193
    +5
    Hi Scott,
    Sorry. I only know how to turn off the AVLS as that is a limiter. Not sure if you can go beyond this level.
    Generally I find it is loud enough with this off. Pumped into a stereo though it isn't I have to admit and not convenient to lug round the docking station for the line out fascility.
    If anyone else can help out I'd be grateful too.
    Cheers,
    Neal.
