unlocking sony dav dz700fw
M
mickw
Can someone please give some advice on trying to unlock my new sony dav dz700fw dvd player .Thanks
[email protected]
Established Member
Should have bought it pre-modded from a specialist dealer! :)
On a serious note, there are no built in handset hacks for Sony models, and its usually cheaper to buy such a machine pre-modded via one of the many specialist dealers (even many Sony centers offer this service). If you do a quick search of the handset hacks forums for "sony" you should find more info as to your options (i.e via laptop, PDA, or using a "chipping" company).
[email protected]
Established Member
danjaq
Established Member
How can you tell which firmware version you have, so I see whether I need to update it?
Also, will changing the firmware in any way affect the multiregion aspect?
Thanks.
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
