unlocking phones from abroad
Discussion in 'Mobile Phones Forum' started by tricky05, Mar 30, 2005.
  1. tricky05
    tricky05
    Thinking of buying a phone of ebay but it is from abroad so the seller says it may need unlocking if it is to be used in the uk. Is this possib;le ? will i be able to use it in the uk or is this just a conn ?
  2. meta1
    meta1
    Depends what network it is, Vodafone is a universal network (can be used in UK + US etc..) such networks as Virgin UK and T-Mobile UK only work, in the UK.. it's worth doing a bit more research first. But otherwise they will need unlocking.
  3. lynx
    lynx
    Jan 20, 2002
    4,633
    It always rains.
    +301
    Many handsets sold on the Continent are not subsidised by the network and are not subject to locks being set. Which handset is it ?
