Unknown Speakers - Need help
Discussion in 'Home Cinema Speakers' started by breney, Jul 31, 2012.
  1. breney
    breney
    Jul 27, 2012
    28
    3
    Hi there, a very silly newbee question!
    A building was prewired and had in ceiling speakers installed a while ago, but all I have been left is this sheet. I want to add an amplifier to these speakers in order to play background music through. There are 4 speakers.
    Does anyone know what sort of speakers they are, and what sort of amplifier would work with them
    Thanks!
  2. Arcam_boy
    Arcam_boy
    Jun 13, 2006
    12,023
    2
    Birmingham
    +2,372
    They look like high sensitivity, speakers and pretty much any amp should drive them.
    I guess it depends on your budget and needs.
    I would recommend a Sonos ZP120 which will happily drive all four speakers and gives you spotify/napster access plus you can use a NAS drive to store your files on.
  3. breney
    breney
    Jul 27, 2012
    28
    3
    Thanks - I found them on the inter web. They are 16 ohm apart audio speakers, so if i wire them in parallel, they will run from a 4 ohm amp? How would i wire in parallel to a single channel?
