'Universal' Remotes
Discussion in 'Home Cinema Control & Remote Controls' started by BD, Aug 13, 2000.
  1. BD
    BD
    Does anyone know a good place to get cheap 'Universal' remote control?
    I'm on a fairly tight budget so I was thinking about the Philex Wizard or the One-For-All Topline 8 that are reviewed on this site but I can't seem to find anywhere that sells them.
  2. Guest
    www.richersounds.com (and their shops) are doing an excellent remote for £30.
    [​IMG] ©
    It's called the Cambridge Audio M500. I had one for a few weeks and everything was excellent apart from a minor annoyance it had with Thomson VCRs.
    Great remote though.
    A Phased Plasma Rifle In A 40 Watt Range®
    My DVDs
    [This message has been edited by Gary (edited 13-08-2000).]
  3. wwwebber
    wwwebber
    Jul 17, 2000
    214
    28
    Nottingham, England
    +64
    I have a One For All Topline 8 that you can buy if you want. I have upgraded to a Philips Pronto. Email me if you're interested.
  4. logiclee
    logiclee
    Aug 9, 2000
    1,676
    116
    Notts, UK.
    +718
    BD,
    Have to agree with Gary, Richer sounds are doing great deals at the moment, the Cambridge Audio A1 is a first class gizmo and now only £79. Some of the other tackle in the Cambridge range is also good value, got some pacific interconnects for my Hifi setup and I'm well impressed.
    Lee
