Universal Remote MX3000 adn Samsung 945
Discussion in 'Home Cinema Control & Remote Controls' started by Neil Fellows, May 3, 2005.
  1. Neil Fellows
    Neil Fellows
    Apr 6, 2004
    301
    Hi there,
    I'm using a Universal Remote MX3000 with its wireless base station, and individual 'flashers' from this taped onto each device. All is well with all devices except the Samsung 945 DVD player which does not like the stick on flashers at all. Strange thing is, if I use the remote directly (just by pointing it at the unit, not going via the wireless base station and flashers) it works perfectly. I've tried the flasher stuck on at a distance and with different positions, and used other flashers, but alas the IR detector on the DVD payer does not like them at all.
    Any ideas?
