Ok so I opened it up and everything works fine - well everything but one thing. Why is it that things are so crappily designed these days. Its not as if they are dirt cheap - they are expensively badly designed.
What am I talking about - Let me explain - I had two things delivered this week, the first a silicone case for my ipod (bad design means without one it will scratch to buggery). The only problem with the case is that the screan protector moves about which would probably scratch the ipod it was trying to protect had I not left the plastic cover it came with on.
The second was the universal dock connection kit - all fine with this apart from one thing - I can't get the stupid ipod in the stupid dock with the stupid silicone case on it
So now I have an expensive dock with an expensive ipod sitting in it held in place by something fairly well designed and cheap - blue tac !!
What a load of bollards.
Questions for any other dock owners out there - how did you solve this problem? Also when you dock an ipod the volume goes to maximum - what happens when you undock it? Does it return to the original volume or am I going to forget and blow my ear drums next time I use it undocked ?
Cheers all - I am off to thrash a granny smith so I can feel like I am getting my own back on apple.
