Unistrutt and Sony 1272's
Discussion in 'Projectors, Screens & Video Processors' started by shaunr, May 3, 2002.
Thread Status:
Not open for further replies.
  1. shaunr
    shaunr
    Apr 20, 2001
    547
    Darlington - Co Durham
    +17
    Anyone had any experience of using this stuff?
    The guy i'm buying my projector from is including Unistrutt to mount it, but i will need to buy a couple of bolts as he only had 2 left.
    Can these be bought from the like of B+Q or are they a specialist item?
    If anyone can give me some advice on getting the thing up there i would be grateful. I'm currently wadeing through my search results from the AVS Forum.
    Cheers,
    Shaun
  2. Mr A
    Mr A
    Unistrut is a commercially available fixing system. Electrical contractors/mech installers use it as a cheap and nasty solution to fix anything to everything rather than designing proper stuff for the job. Try an electrical wholesaler such as City electrical factors they may have it, B&Q dont as it is not conventionla DIY stuff.
Thread Status:
