Uninterruptable Power Supplies and Projectors
Discussion in 'Projectors, Screens & Video Processors' started by DarrenH, Mar 9, 2005.
  1. DarrenH
    DarrenH
    Jul 20, 2004
    577
    Kent
    +7
    Hi does anyone use UPS with their Projector in case of power loss and damage to the bulb? If so, is there a specific type I should be looking at or anything that will keep the PJ going for a while to cool down?
    All advice appreciated. :smashin:
    Darren
  2. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    I use a UPS that cost £50 and is 1200Va, although I would have thought this is being a little overoptimistic on the manufacturers point of view. Nothing in particular to look for but dont get the cheapest one possible (<£30) or it may cause some unseen problems. It only needs to be able to run it for 5mins or so, therefore a 600Va of decent quality should be fine I would have thought....
  3. CooperUK
    CooperUK
    Jun 30, 2003
    2,240
    Hampshire
    +318
    Where did you get a 1200vs UPS for £50?
    I'm looking for a UPS at the mo' and that would fit the bill nicely!
    Cheers,
  4. DarrenH
    DarrenH
    Jul 20, 2004
    577
    Kent
    +7
    That does sound cheap!
    Had a look and found a Trust 800 VA for £40 with anti-surge, RFI screening, Power conditioning... Does this sound like a good option? :confused:
  5. explicitlyrics
    explicitlyrics
    Apr 26, 2003
    1,149
    41
    NW London
    +18
    I got it from www.ebuyer.com however I think they have sold out now. The trust one you mention seems like it would work fine in he circumstance.
  6. DarrenH
    DarrenH
    Jul 20, 2004
    577
    Kent
    +7
    Thanks for the advice :thumbsup:
    Darren
