New Patreon Tier and Early Access Content available. If you would like to support AVForums, we now have a new Patreon Tier which gives you access to selected news, reviews and articles before they are available to the public. Read more.
Ok so I add the laptop as a device and then set power on to none? The activity that turns it on is 'watch tv' would I still need to look into this activity in more detail?
there was no option for the power on command after adding the HP laptop. I also reviewed the watch tv action and it doesnt mention any devices other than those that are needed to 'watch tv'
The location for changing the power on and off commands is Devices> Settings> Adjust Power.
As the startup procedure doesn't include the device to be powered on then the Harmony can't send any power command to it.
What you were expecting is exactly what you should be presented with.
You have been to the page "Do you want to leave the device on all the time" and the second page after that is "Which command turns your device on or off" with the second option being to select the command from a dropdown list on which the first entry is "none". Let me know if that page does not appear.
No, I have nothing to do with Logitech and the name is a coincidence. It's another word for "computer".
It could be that the computer responds when it shouldn't?
My father's Acer laptop doesn't power on by remote, but it does "cancel" the screensaver when a button on the Samsung TV remote is pressed.
i found the settings eventually, didnt know I needed to proceed past that page. it was actually a few pages into that menu.
I have set it to no action and also put some black electrical tape over the infra red port on the laptop... together that should have sorted the issue!
Yes, the number of page options at Adjust Power for different devices may vary according to their capabilities.
As you have set the Harmony to send no command to that device the tape would only be blocking IR from some other source.
Logicel master of all things logitech.. My hard drive always turns on fine when I click watch a movie but then when I'm finished and I choose watch tv or even all of it's the only thing that stays on.
When I go to help it will eventually turn off but it's getting frustrating. Where in the software would I need to go to rectify this?
