Unicol Bracket and VW10/11/12HT
Discussion in 'Projectors, Screens & Video Processors' started by spiderv6, Apr 14, 2003.
  1. spiderv6
    spiderv6
    Dec 12, 2002
    138
    16
    Is anyone using the Unicol bracket with this PJ?
    Did you go for the GK1 (with 23-30cm extension) or the GKC close ceiling model?
    I like the idea of the close ceiling model but worried that I will not have enough clearance if it is so close to the ceiling.
    Thanks!
  2. Russ
    Russ
    Aug 3, 2000
    203
    Warwick, UK
    +16
    I use the GK1 (do a search on UNICOL to see my other comments about this company).
    The mount is solid and versatile. No complaints about quality or function.
    Note I calculate that the mount center is 34mm from the lens axis, not 40mm stated in the manual, which is correct only for the Sony mount.
    I think the close mount may have two problems;
    no clearance for the projector and
    the top of the screen would be very colse to the ceiling unless you point the projector down a bit and then you would get some trapezium issues.
    Remember, if you want a white one - make your choice at the time of ordering !
