unfinalizing: this happened to you?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Lee J B, Aug 26, 2004.
  1. Lee J B
    Lee J B
    i've got a new toshinba dvd recorder....i've noticed that sometimes after i've unfinalized a dvd-rw it tells me it doens't recognise the disc, and it means i've got to format the disc - and lose what i have on there!
    I'm not sure at this stage whether it's the dvd recorder at fault, or the cheap dvd-rw's that i'm using (these are the first rw's i've used since purchase). I just wondered if this problem has happened to anyone else?
    It doesn't always happen though. sometimes i can unfinalize and the data on the disc and its' still there for me to re-use/delete or whatever. however, not being 100% on whether it'll work means that if i ever part-use a disc and finalize it for use on another machine, i'll have to make damn sure that i dont need the stuff recorded on the dvd!
    thanks for any input...
    Lee
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    i have had this, i think its the media
    was they bulkpaq by any chance
  3. Bob H2
    Bob H2
    Aug 27, 2004
    34
    The Toshiba gives the same message when a DVD is finalised.
    Would appear to me to be a software problem. Try adding something to the DVD and see what happens.
