Underworld - Superbit
Discussion in 'Movie Forum' started by BAN5HEE, Sep 19, 2005.
  1. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,218
    Chelmsford
    +515
    Does anyone have Underworld in superbit? I have the 2 Disc set which has the DTS soundtrack but I'm just wondering if it would be worth getting it for the better picture quality?
  2. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    I believe there is a Jap version with both the extended cut of the film and a DTS soundtrack which is probably the best version :)
  3. Ger
    Ger
    Jun 9, 2003
    1,620
    Ireland
    +83
    The R2 versions (both cuts) contain DTS tracks and fill up most of the disk's space (both cuts have all the extras on a separate disk), so they are more or less superbits anyway. The R1 version was released by Sony so they withheld a DTS track until the Superbit version (as usual), but the R2 was released by EIV.
    So if you have the R2, I doubt there is any point in getting the superbit.
  4. Hugh
    Hugh
    Mar 31, 2003
    2,433
    116
    Birmingham
    +1,600
    If you have the ability to play/display high definition, then you may want to check out the 720p WMV-HD disc. It is the extended print.
    This may well be the best looking disc out there, although I haven't checked out the 1080i print that is also about.
    Anyone compared the two? Barring in mind if I had the 1080i, I'd be downscaling it to 720p anyway for my projector's resolution. 1080i PJ's are still a bit pricey at £14,000
  5. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,218
    Chelmsford
    +515
    I know about HD version but don't have anything to take advantage of that at the moment. Kate Beckinsale in HD hmmmmmm
  6. Thunder
    Thunder
    Feb 26, 2004
    1,830
    41
    +14
    Unless you get a 9" CRT for about 6k :smashin:
  7. Razor
    Razor
    Dec 15, 2004
    37,615
    2
    +12,442
    BANSHEE :hiya:
    I have the HD verson and it is very good, could you not connect up your pc to watch it? :D
    Underworld HD
  8. avmunster
    avmunster
    Aug 12, 2002
    198
    Hartlepool
    +5
    Did you buy the wmv-hd from that website? I could do with some of these movies as I have a Z3 setup now. Are there any other places selling them?
  9. Razor
    Razor
    Dec 15, 2004
    37,615
    2
    +12,442
  10. BAN5HEE
    BAN5HEE
    Jul 26, 2004
    4,218
    Chelmsford
    +515
    I might come and "borrow" your RD65 :devil:
