Underworld R1 problem
Discussion in 'Movie Forum' started by PJnewbie, Jan 18, 2004.
  1. PJnewbie
    PJnewbie
    Hi guys,
    I have a Sony S735 DVD player and have played many recent R1 DVDs with no probs at all (Finding Nemo, Italian Job etc.)
    However, Underworld R1 will not play. It gives me a world map, advising that it will not play on modified players.
    This is the only DVD that has ever given this problem. Is there any way around it?
    Many thanks.
  2. sapperjohn
    sapperjohn
    Jul 23, 2003
    187
    2
    Devon
    +7
    An RCE disc by th sound of it. regional code enhancement
    Try playig a different R1 disc that does not give the RCE message. Then eject and put the Underworld disc in and press play. Works on my old Pioneer 626, may work for your machine
    Sapperjohn
  3. Phil Hinton
    Phil Hinton
    Editor Staff Member
    Jan 18, 2001
    10,011
    3
    +7,728
    I get this on my Onkyo and do what Sapperjohn mentions and it works fine then, try it.
  4. PJnewbie
    PJnewbie
    Tried this lads, and no joy. Still the map of the world:-(
    I put in R1 Finding Nemo, also tried Italian Job and Pearl Harbor, but no luck.
    It seems a further hardware mod is my only option.
    Cheers.
  5. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    If you can set the region manually on your player (most are set to 0 for multi region playback), then set it to 1. This may work also.
