Underworld Evolution R3 & DVD Profiler
Fatti
I've just received Underworld Evolution Region 3 from CDWOW and am trying to get it into DVD Profiler. However, there isn't a barcode on the back of the case, just an white box (where the barcode should be) with some numbers and letters. I've tried entering it by Disc ID, but get: Current Disc: UNDERWORLD_EVOLUTIONS (F3DF5A07), and Title: (unknown). If I select Add Now from here it tells me there are no DVD titles selected.
Has anyone had this before and have any ideas?
Soundwave
I know it's not the same but I have the R1 version here if you want the barcode from that to input into profiler??
Neil
Fatti
Hi Neil..thanks for that. The 'add disc by title' part has a number of region 1 barcodes, so I suppose I could have picked one of those. However, I went to the Intervocative forum (should have done that before I posted here :suicide: ) and found that if you add by title and untick the 'Download Profile from IVS' it will let you enter a title by Name, Region and Locality. You have to fill in all the blanks, but at least I'm further than I was.
Thanks again for the offer though :smashin:
Soundwave
No worries your welcome.
Glad you managed to get it sorted.
Neil
