Underwater video - Pal-B vs UK compatibility
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by DonkD, Jun 22, 2005.
  1. DonkD
    DonkD
    Hi there. Planning on purchasing a USA sourced underwater video camera system (into the UK) which they can apparently supply in PAL-B rather than NTSC. Currently feed old camera video signal into a Sony GVD1000 (PAL) mini DV recorder and display on standard UK PAL monitor.
    However, I have been told that there would be compatability issues between a PAL-B system and the Sony GVD mini DV recorder we use - in that this would be UK spec PAL-I. :confused:
    I have been aware of NTSC vs PAL issues, but hadn't realised that there were also issues between different PAL systems - i.e. different countries within Europe.
    Any ideas on whether a PAL-B video signal into the Sony GVD1000 (potentially PAL-I) would be an insurmountable problem?
  2. Brian110507
    Brian110507
    There's a table here which may help you :-
    http://lea.hamradio.si/~s51kq/STANDARDS.HTM
    there is a table at the very bottom of the page which compares various PAL systems - PAL-B seems to diifer slightly in video bandwith and audio carrier frequency, I think if it was me I'd want to try before I buy to be sure
  3. DonkD
    DonkD
    Thanks for that -it confirms what I'd heard elsewhere. The extent to which it will be a problem is unclear - hence ideally a try before buy approach, but unfortunately as its coming from the States, then that's not going to be so easy. May just shelve the idea and buy a UK kit, although as usual, the cheapest is around twice the price as the US ones.
  4. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    The Garden of England
    +32
    What sort of underwater videoing do you want to do - depth wise that is - there are plenty of options out there...
    - one of the best sites I've found is here . I've got an EWA flexible housing
    - mainly for snorkeling and using on the beach with the sand worry - an excellent purchase (even the Mrs agrees with me :zonked: .....)
  5. DonkD
    DonkD
    Planning to use video for shallow to semi-deep water seabed drops - c. 20-50m. As such, needs to be fairly robust kit (rather than simple housing for terrestrial camera) and needs a good light supply. Risk of loss due to snagging etc means it can't be too pricey - i.e. under £1k.
  6. shoehorn
    shoehorn
    Jul 2, 2003
    1,610
    +32
