Understanding POE Injector vs Switch
MrM
Established Member
Hi forum,
I've just bought x2 REOLINK RLC 410 5MP cameras for my property.
I currently have a 1 month old Sagemcom [email protected] 5364 Router that I use with Talk Talk internet.
I'm wanting to run both these cameras over PoE. My booklet with the RLC 410's say that I must use an 802.3AF (48V) Switch or Injector for this model of camera.
Given my current set up is just x2 cameras - will I be OK with a 2 Port PoE Injector? If so, can anyone recommend one at all please?
Am I correct in understanding that a PoE Switch is only needed if you''re running many POE devices?
Thanks in advance.
Seb Briggs
I personally would use a POE switch than a passive injector, a 4 port POE switch can be had for around £39.
Passive injectors I have found to be troublesome though they look cheap on the face of it.
Seb
MrM
Established Member
Seb
Thanks for that Seb, I will look at POE Switches instead. Do you have any brand recommendations?
Fabien
Established Member
Check the specifications of any PoE switch also. I’ve had them not supply enough juice before now when the end device required it. There are a number of ‘classes’ when it comes to PoE. Also if it’s a managed switch there maybe some subtle settings you need to tweak to make sure PoE is configured correctly.
Fabien
Tribit StormBox Blast Bluetooth Speaker: Review Coming Soon
