understanding avia?
Discussion in 'Projectors, Screens & Video Processors' started by rory29, Dec 15, 2002.
  1. rory29
    rory29
    I get a little confused when it comes to adjusting the
    Red Blue & Green settings on my plv30 using avia.
    Setting overall colour is straight forward enough,
    but can avia help me with the indivigual elements
    any ideas anyone.
    Rory.:)
  2. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Hi Rory,
    Yes it can. Go to Chapter 7 (Calibrations). Under "Special Tests" select the first one: "Color Decoder Test".
    You can use it to check up the "Push" your PLV30 is inducing to any of the 3 RGB colors.
    Very useful.
    HB
  3. Smurfin
    Smurfin
    Aug 13, 2002
    21,442
    +4,386
    You use the colour filters on that part, similar to earlier tests. Adjust the colours until the 0% square on the coloured bars match the background colour - or near as dammit!
  4. AlfaKhan
    AlfaKhan
    Aug 7, 2001
    250
    Cascais, Portugal
    +6
    Correct.
    ...But, actually, overall "push" is a question of personal preference and projector performance.
    I like to calibrate my PLV30 with a +15% "push" on red, but what do I know...:rolleyes:
    HB
  5. rory29
    rory29
    Thanks for the replys guys,
    looks like i will have to get the old coloured squares
    out tomorrow and have a good sess.
    Rory:)
  6. ROne
    ROne
    Dec 21, 2000
    781
    +8
    The colour decoder check doesn't work like this. It is for analysing the accuracy of the decoded saturation's individual components. You can only compensate for Red push by lowering you saturation.
    The RGB on a projector refer to the mix that creates the absolute white point or white balance of your projector even if there was no colour in the signal.
    However by lowering the R of the RGB settings you will lower greyscales Red component and the picture will seem more G/B, but across the white element of the picture not the saturation.
