Underpowering an LED strip
Discussion in 'Home Cinema Buying & Building' started by wellsi, Jul 7, 2015.
  1. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Just after anyone's experience on under-powering LED strips. I have a 120w 24v transformer and would like to power a 10m 5050 RGB 24v strip that has 60 leds / m.
    Assuming 0.25w per LED, that's 600 x 0.25 = 150 watts. Will I ruin the LEDs if I only supply 120w? Having them a bit dim is fine. I'm assuming I can't overload the transformer as it will ony give out what it can.... but any advice welcome.
    Ian
  2. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    Portsmouth, Hampshire, UK
    +166
    Wrong assumption!!
    In theory, 2 off 60/m strips will need 14.4W/m x 10m = 144W running flat out = all R G & B LED's ON = bright white, so you are not far out on that score.
    Running a switched mode power supply higher than around 80% of its rating will reduce the lifetime as it is working quite hard even at 80%.
    So in theory you will need 144W/0.8 = 180W for good reliability.
  3. wellsi
    wellsi
    Mar 28, 2002
    494
    London, UK
    +29
    Fair enough! Thanks for the advice!
    Ian
  4. Member 721023
    Member 721023
    Jun 24, 2015
    34
    11
    London
    +7
    I would also like to add a tip; usually more than 150 Watt chassis PSU will have a built-in fan and that will cause some noise that could be disturbing if installed in silent enviroment. For this reason I would suggest an enclosed switch mode PSU (IP67) not less than 180W as very correctly already suggested to you.
  5. supraTTman
    supraTTman
    Feb 1, 2011
    1,007
    +166
    Good point Hiline, I have found with my several psu suppliers that the threshold between fan-less psu's and fanned psu's to be around 20A/12V = 240W or 10A/24V =240W same power factor.
