Underlay for Engineered Wood Floor
Discussion in 'General Chat' started by joust, Jul 11, 2018.
Tags:
  1. joust
    joust
    Sep 4, 2002
    1,077
    48
    Blackpool, Lancs
    +77
    Hi all,
    Will be laying approx. 68m2 of 18mm wood floor - does anyone have any reccommendations for which is the best (and most cost effective) underlay to buy and fit?
    Joust
  2. teljess
    teljess
    Jan 29, 2004
    3,350
    lowestoft
    +709
    What are you laying the floor on, if it’s on concrete or a chipboard floor then you glue it down and you don’t use underlay
  3. joust
    joust
    Sep 4, 2002
    1,077
    48
    Blackpool, Lancs
    +77
    Its going down onto a chipboard floor......but wasn't keen on gluing it, as you never know if it may need to be taken up for some reason in the future.
  4. danmc_82
    danmc_82
    Jan 19, 2007
    5,680
    Skynet Border
    +1,245
  5. teljess
    teljess
    Jan 29, 2004
    3,350
    lowestoft
    +709
    Have you got a link to the floor your having ?
  6. Wahreo
    Wahreo
    Oct 11, 2012
    15,503
    +12,843
    When I did mine I used timbermate xl or something.
  7. joust
    joust
    Sep 4, 2002
    1,077
    48
    Blackpool, Lancs
    +77
  8. MrFraggle
    MrFraggle
    Jan 12, 2012
    4,300
    Edinburgh
    +6,807
    No matter what you are laying the flooring on you certainly need decent soundproofing underlay.
  9. Wahreo
    Wahreo
    Oct 11, 2012
    15,503
    +12,843
  10. teljess
    teljess
    Jan 29, 2004
    3,350
    lowestoft
    +709
    Are you secret nailing,floating floor ?
  11. joust
    joust
    Sep 4, 2002
    1,077
    48
    Blackpool, Lancs
    +77
    Will probably look at secret nailing...
  12. MrFraggle
    MrFraggle
    Jan 12, 2012
    4,300
    Edinburgh
    +6,807
    He is hardly likely to make it known on the forum if he is surely?:rotfl:
  13. danmc_82
    danmc_82
    Jan 19, 2007
    5,680
    Skynet Border
    +1,245
    I wouldnt recommend using nails on woodchip flooring, they may become loose in a short while and squeak like mad. Screws would be better.
  14. teljess
    teljess
    Jan 29, 2004
    3,350
    lowestoft
    +709
    To be honest I would use this Flooring Adhesive | Laybond Wood MS Bond | Bostik
    I use this all the time we laying engineered wood flooring,you put it down using a 6mm notched trowel and as long as the sub floor is sound then you will not have any squeaking
  15. danmc_82
    danmc_82
    Jan 19, 2007
    5,680
    Skynet Border
    +1,245
    Can't really use that if he's using an underlay. Either screws or leave floating are the best choices.
  16. teljess
    teljess
    Jan 29, 2004
    3,350
    lowestoft
    +709
    You don’t use underlay when glueing the floor down
  17. danmc_82
    danmc_82
    Jan 19, 2007
    5,680
    Skynet Border
    +1,245
    I know, thats why I said it. But the title of the thread is called " Underlay for Engineered Wood Floor"
    so I assume he wants it ;)
