under utilised SR5400
Discussion in 'AV Receivers & Amplifiers' started by doublej, Jul 3, 2005.
  1. doublej
    doublej
    Jul 3, 2005
    122
    +13
    ...not an audiophile by any means, however I am passionate about music and would like to create and immersive sound for my music and games console :rolleyes:
    i have an sr 5400 with some mission m70s.....a 50 quid after thought, pluss a cambridge audio CD 36 (you can guess where I bought it), The CD Player hums a bit but other than that is fine for its occaisional use - since most of music is now from my computer.
    it might sound like an odd system , but mission control isnt large. (ok, other people would call it the spare room). I bought the sr5400 for its flexibility.' I may deploy it elsewherer in future.
    In the meantime.... i want mission control to be more filled with sound. I actually have a lovely revealing image (if bass-less) with the missions - but it sounds very directional and "from' a source you could point at"....make sense' ??
    thanks to the marantz...i have a bunch of options open...' so :
    - move the m70s to become rears and spend more on a hot stereo pair ?
    - retire them downstairs and buy a hot stereo pair
    - buy a small 5.1 / 6.1 set - KEF eggs ? M-Cubes ?
    - buy a large 5.1 / 6.1 set
    - all of the above
    - none. of the above
    money of course, is simply not an object. :rotfl:
    at least it wont be once the existing stuff is paid for.
    JJ
  2. doublej
    doublej
    Jul 3, 2005
    122
    +13
    did i post this in the wrong forum or am i just impantient ?
    jj
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    This forum should be fine.
    I think you need to be looking at new speakers which are better at creating a soundstage. Also make sure that you're listening in stereo rather than the multitude of surround options - assuming you do only have the pair of speakers and no centre/rear to think about. :)
  4. doublej
    doublej
    Jul 3, 2005
    122
    +13
    any more for any more ?
