Under plasma cabinet
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by suniil, Oct 21, 2005.
  1. suniil
    suniil
    Jan 24, 2005
    4,948
    London SE5 / W1
    +402
  2. AMc
    AMc
    Nov 20, 2000
    7,652
    Near Norwich
    +4,422
    Might work but check the depth of the units you want to put in it - my AV amp needed 45 cm + clearance for the cables.
    Also check to see if the back is needed to hold the whole thing square. You'll need to cut access holes for cabling and depending on what you put in there heat escape.
    IKEA do some decent hifi and TV furniture - you might be better buying something more specifically designed to do the job.
