Under floor speaker cable
Discussion in 'Cables & Switches' started by cadmeister, May 3, 2005.
  1. cadmeister
    cadmeister
    Nov 12, 2002
    107
    19
    Milton Keynes, UK
    Does anyone know a good source of flat speaker cable for going under wooden floors ? A friend gave me a sample that was apparently on the front of one of the magazines and it's <1mm thick and would be perfect for my rear speakers. Problem is it is unbranded and no one seems to stock anything similar.
  2. stu mcc
    stu mcc
    Nov 13, 2004
    588
    +23
    richer sounds do gale hyperlitz at £1.50 a metre which is flat and pretty flexible.
    stu
  3. stu mcc
    stu mcc
    Nov 13, 2004
    588
    +23
    or even flatter is qed qontour which is around £2/m, think that's about the flattest you can buy.
    stu
  4. spiver
    spiver
    Dec 26, 2004
    1,110
    48
    +33
  5. MacReady
    MacReady
    Jun 25, 2003
    2,263
    Barnsley, South Yorkshire
    +126
    I am using QED Qontor and it is VERY flat (about 1mm ). It uses 6 solid copper strands and is very good at bending and holding it's shape.
  6. cadmeister
    cadmeister
    Nov 12, 2002
    107
    19
    Milton Keynes, UK
    Thanks for the replies, but the sample I have is actually flat copper not strands - I've attached a link to a pretty crappy webcam shot so you can see what I'm on about. Any ideas ?
    Crappy webcam shot
  7. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Here's some ultra flat copper cable, 0.18mm thick. Doubt you can get flatter than that!
  8. aldavies
    aldavies
