Under-cabinet LCD mount
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by LDJ, Jun 3, 2004.
  1. LDJ
    LDJ
    Jun 18, 2003
    606
    +27
    I'm looking to buy a mount for a 17" LCD screen that will affix the unit to the underside of a kitchen unit.
    This was recommended to me on another thread, but I cant find anywhere in the UK that sells it, and haven't had any luck finding an alternative.
    Can anyone recommend a suitable alternative, or somewhere the above item can be bought?
    Many thanks
    :thumbsup:
  2. bobbypunk
    bobbypunk
    seen them about go to "contact us" and e-mail BBG the english distributor and they will let you know you're closest dealer
  3. LDJ
    LDJ
    Jun 18, 2003
    606
    +27
    Thanks bobby. I did email them and they responded this morning, but unfortunately cant locate the abovelinked mount. They offered an alternative, but it wasn't really suitable.
    Is there any other 'under cabinet' mount available?
    TIA
