Uncompress using STR-DH800 or PS3?
GCaster
Hi.
I've recently bought a Slim PS3 to go with my setup (see sig) and have one question about the Blu-Ray audio.
Am I going to get better sound having the PS3 decode the audio and send it to the amp in PCM form or should I set the PS3 to bitsream the audio from the blu-ray and get the amp (Sony STR-DH800) to do all the decoding?
I'm guessing the amp will do a better job of the decoding than the PS3 and am kinda thinking this is a bit of a stupid question! (I'll also get the HD lights on my amp too which seems to make me happy! :thumbsup:)
Please let me know if I'm right.
dante01
The results will or should be exactly the same, although you could actually try it for yourself in order to determine which is the best for you …
… or are you deaf???? :D
a codec
is a codec
is a codec
regardless of which component it is used in ;)
Mark.Yudkin
From an audio viewpoint the sound (of the common subset) is identical - as Dante01 explains. From a functional viewpoint, you sacrifice functionality (e.g. audio mixing) by not decoding on the player. So the answer is that if the looking at a shiny light on the amp instead of watching the film is more important than full-function audio, then bitstream. Conversely if audio functionality is more important than a useless light, then decode in the source.
