Question Unclear dialogue on my Home cionema setup
Discussion in 'Home Cinema Buying & Building' started by spenn, Jun 11, 2015.
  1. spenn
    spenn
    May 19, 2015
    24
    London
    Hi, sorry but anther question.....
    I have a Panasonic TX37s10b TV, Marantz NR1602 AVR, Kef 2005 speakers and a Panasonic BDT130 Blu ray. All great when playing music, watching movies or action type TV programmes on Sky HD . However, when watching non HD stuff or programs which are mainly dialogue rather than effects and music, I am having to crank up the volume to get clear definition. Are there any settings I need to adjust? Is my centre speaker ( positioned just below the TV centrally) in the wrong place? Any thoughts gratefully appreciated
    Best
    Steve
  2. spenn
    spenn
    May 19, 2015
    24
    London
    Sorry excuse the typo on the heading!!!!
  3. Pearfish01
    Pearfish01
    Nov 9, 2007
    306
    Bushey
    +8
    Centre speaker is in the right place without seeing a pic. If it's not at ear level try point in it up etc. you could go into the speaker settings on your amp and turn it up a decibel or two.
  4. spenn
    spenn
    May 19, 2015
    24
    London
    Thanks Pearfish01 I will try the settings on the amp
    Steve
  5. Ghostrider
    Ghostrider
    Jan 3, 2006
    884
    43
    Warrington
    +127
    Non-HD stuff is likely to be a Stereo mix and unless you have your amp set to create a pseudo surround field - something like pro-logic - then you are probably getting audio from your L&R speakers and not from the centre.
    If my amp settings get messed up - sometimes the dog can bump into it - I find I get this problem and it just doesn't sound right - a bit indistinct, fuzzy and disassociated with the picture if that makes any sense whatsoever.
  6. spenn
    spenn
    May 19, 2015
    24
    London
    Yes...it does make sense. I am ging to try to turn up the centre speaker a touch and see if that works
  7. PSM1
    PSM1
    Dec 20, 2008
    26,285
    +5,443
    If it sounds fine with 5.1 sources then raising the centre is not really going to help and could possibly unbalance the front for the 5.1 source so make these not sound as good.
    As Ghostrider says, try a few of the different settings like Prologic or Neo6 to see if these improve the sound first.
  8. spenn
    spenn
    May 19, 2015
    24
    London
    OK...thanks for this. I will try the settings first and let you know.
    Best
    Steve
  9. Rick84
    Rick84
    Feb 16, 2013
    2,577
    Doncaster
    +627
    I would get this issue with my older Marantz SR7005 and Apex setup. I found raising the frequency and volume of the centre channel helped with dialogue.
  10. spenn
    spenn
    May 19, 2015
    24
    London
    Hi. Thanks for this.
    Changed the settings and watched on NEO which was a touch better. I have also changed the level of the centre speaker and , again, a bit better.
    I am watching sport in multi channel stereo which seems to be effective.
    Will keep experimenting with different surround settings for movies and let you know.
    Best Steve
  11. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,934
    The Borders
    +3,576
    If you are raising the Centre when on a Stereo channel you have the AVR in one of its pseudo Surrounds modes.
    Try setting the AVR to Stereo (disabling the Centre and Surrounds) and see how that works out.
    Joe
  12. spenn
    spenn
    May 19, 2015
    24
    London
    Joe I actually already tried this in multi channel stereo mode which worked quite well.
    Steve
