unbeatable.co.uk gone into administration...
Discussion in 'Plasma TVs Forum' started by italianninja, Aug 30, 2005.
  1. italianninja
    italianninja
    Jul 30, 2005
    159
    I just cant believe it if you goto the homepage, http://www.unbeatable.co.uk you will see a messege "This site is temporarily unavailable while we carry out major updates." its rubbish. I called them and the answer messege said they have gone into administration!
    Where else am i gunna buy my th42pv500wal and tannoy areana 7.1 system? with 12 months 0% finance?
    ahhh, i want to cry! :suicide: :lease:
  2. salfordred
    salfordred
    Feb 2, 2005
    89
    I was looking at using Unbeatable, but I have found what I need on buyyourav.com
    They are little bit more expensive, but do offer the 12 months.
    Think I'll give them a go.
  3. italianninja
    italianninja
    Jul 30, 2005
    159
    they have the th42pv500wal but not the speakers or the amp i want! :thumbsdow
